ZMR 250 mon 1er drone !
guillaume22
Re: ZMR 250 mon 1er drone !
Message par guillaume22 »
Réponse de FAtshark a ce probléme
Fat Shark just replied on Facebook:
This lithium polymer battery pack is equipped with an internal cell balancing circuit that allows the battery to be charged from standard RC battery chargers. Charge the battery by connecting the barrel connector via the supplied adapter cable and setting the charger for 7.4V, 1800mAh Li-Po, 1.8A (1C).
Some RC chargers require a balance lead connector to be connected to the charger, or else the charging attempt will result in an error. The balance lead on the battery is not a true balance lead and is only used for powering the optional fan faceplate. To charge this battery set your LiPo charger to Fast Charge mode, which usually disables the balance lead requirement (set at 7.4V – 2cell - maximum 1.8A).
On some LiPo chargers none of the above procedures will work. In that case you can set the RC charger to NiMH mode and set max charge rate to 1.8A (1C)
Note (1): In NiMH mode the charger may fail to announce completing the charge. You should be able to estimate your battery charge amount by either timing (a fully depleted battery will charge in 1 hour at 1C) or monitoring the mA charge rate on the RC charger display (will drop to almost zero as it becomes full). Remember, you can always remove the battery from the charger and depress the battery level indicator button to check the charge level.
Note (2): If battery becomes fully discharged or shorted, an internal safety circuit will trip. To reset the battery, tap 9V direct to the barrel connector via the discharge adapter cable’s banana connector. This will instantly reset the battery and it can be recharged as normal.
Ton chargeur est bleu ou noir ?
Comme un chip gère en interne la charge, tu peux brancher sur Nimh mais à ta place je resterais surveiller la charge au moins les 1re fois.
kaizo
Message par kaizo »
même en fast charge ça marche pas, toujours 'cell error voltage"
j'ai vu avec studiosport, apparemment les nouvelles batteries ne sont plus compatible (ils ont beaucoup de retour, ils vont changer la description du produit...)
j'ai commander le chargeur fatshark à 15€, j'ai pas trop envie de bidouiller les modes ou autre pour cramer ma batterie ou ma maison :/
note pour plus tard le b6 ac v2 ne marche pas avec les nouvelles fatshark!
kaizo
Message par kaizo »
encore un petit souci au niveau du fpv cette fois ci, aucune image ds les lunettes, y a il une procédure spécifique ?
vx : et25r
- lipo branchée (c'est mieux ;-) )
- je mets mon vx avec toutes les diodes allumées ce qui correspond au raceband, je passe d'un channel à l'autre
- sur les lunettes je passe d'un channel a l'autre (les 8 avant de changer sur le vx)
de la neige, rien que de la neige ou du tout gris
dois je avoir un osd quelconque sur les lunettes, un menu ou quelque chose meme si il ne se connecte pas a a la cam ?
y a t il un ordre précis pour allumer, d'abord émetteur, ensuite lunette ?
ma cam est une runcam swift alimentée par le vx (4.5 volt qui arrive sur la cam)
je suis bien sur av 2d
ps: le bouton rx est bien sur 1 sous les lunettes
ps2 : j'ai bien mis un emetteur fatshark raceband ds les lunettes
Il faut forcément une entrée vidéo pour vérifier le bon fonctionnement du VTx, enfin c'est mieux. C'est bien ce qui manque aux FatSharks : un OSD qui montrerait la fréquence configurée, si y'a du signal ou pas...
L'écran gris/noir correspond surement à la fréquence de ton VTx
Les et200r sont capricieux parfois on a besoin de débrancher et retrancher la lipo. Ils ne partent pas toujours direct.
kaizo
Message par kaizo »
bon apres test sur avec un autre recepteur et d'autre lunettes (merci Guillaume !)
j'ai recâblé mon alim de cam direct depuis la pcb plutot que de passer par le vx, j'ai bien 12v qui arrive, et j'ai une image !
mais elle saute, il y a des bandes et a peine de la couleur :/
pas utilisable pour voler...
Filtre LC
kaizo
Message par kaizo »
ok merci j'en ai commandé 1 !
il est a placé plutôt a la sortie de la cam ou la sortie du vx ?
kaizo a écrit :il est a placé plutôt a la sortie de la cam ou la sortie du vx ?
A l'entrée de l'alim des 2, idéalement ;)
viewtopic.php?f=15&t=640
