Foxtechhobby has release a pre-order page for the CONNEX FPV Resolution HD. Price is USD 499.
https://www.foxtechfpv.com/connex-fpv-r ... order.html
Features:
- Uncompressed 720P High-Definition over a Digital-Link
- Support range of up to 1000ft/300m LOS
- Keeping zero latency, real-time video at all ranges
- 30 available HD channels over 5.8GHz (5.1GHz-5.8GHz) with easy to set options
- Offering solution for the novice racer as well as high-end racing
- Providing a spectators mode
- Built-in OSD capabilities
- Region-less Tx compatible with any Rx
- Mobile App configuration tool over bluetooth
Amimon New FPV Zero-Delay Camera features:
- HD 720P camera
- FPV optimized for indoor&outdoor flights
- Advanced hight-dynamic-range supported
- Dimensions-28x20x27mm
- 105 degree FOV with fixed lens
- Compatible with vision transmitter only
- Power up from vision transmitter
- Weight is 13g, 6g for the camera and 7g for the lens
Amimon New FPV Zero-Delay Transmitter specifications:
- Power consumption: 3.5W
- Power input: 6V-15V, 2S-4S battery supported
- Antennas: two external MMCX connectors
- Weight: 30g
- UX: 2 LED- status indication only
- Interface: Power in (4pins)
Power out to the camera&recorder
Micro USB-connection to application; wired pairing
Proprietary MIPI(14pin right-angle,JST SM20B-SRSS)-HD video input
- Environmental: Operating temperature: -10°to 50℃
Operating humidity: 10%-90%
Storage temperature: -10°to 75℃
Receiver specifications:
- Power consumption: 3-3.5W
- Power input: 6-28V, 2S-6S battery supported, reverse polarity protected
- Antennas: 5 antennas(5 external short SMA connectors)
- UX: 2 LED-status indication only;3 push button-for OSD control
- Interface: Power supply jack
HDMI out- type A female
Bluetooth for application management control
Management application:
- Android & iOS Applications
- Bluetooth connectivity from mobile APP to vision ground unit
- Setting your device easily: Manual frequency setting
Regulatin®ional setting
Race mode for setting up races
- Built-in OSD-provides full functionality of OSD menu&buttons:
recording
choosing who to watch
Configuration of recorder, wireless setup&OSD
Your purchase includes:
- 1*Camera
- 1*Transmitter
- 1*Ground unit
- 1*Package of accessories
As expected, it will be using a proprietary cable from the HD camera to the video transmitter.
Range of 300m is lesser than the other Connex models but is sufficient for FPV racing. There is mention of configuration of recorder, so we might be seeing an SD slot in the receiver itself.
