weedo35
Message par weedo35 »
d ailleur pour ceux qui comme moi on galeré a faire els pid du qx et les rate, voici un dump de mon cli, avec les led et tout:
n oubliez de taper save apres avoir copier collé :) ( c est pour BF 3.0)
Code : Tout sélectionner
# version
# BetaFlight/SPRACINGF3EVO 3.0.0 Sep 11 2016 / 00:43:23 (a21694b)
# name
name -
# mixer
mixer QUADX
mmix reset
# servo
# servo mix
smix reset
# feature
feature -RX_PPM
feature -VBAT
feature -INFLIGHT_ACC_CAL
feature -RX_SERIAL
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -GPS
feature -FAILSAFE
feature -SONAR
feature -TELEMETRY
feature -CURRENT_METER
feature -3D
feature -RX_PARALLEL_PWM
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DISPLAY
feature -OSD
feature -BLACKBOX
feature -CHANNEL_FORWARDING
feature -TRANSPONDER
feature -AIRMODE
feature RX_PPM
feature VBAT
feature MOTOR_STOP
feature FAILSAFE
feature CURRENT_METER
feature RSSI_ADC
feature LED_STRIP
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
# map
map AETR1234
# serial
serial 20 1 115200 57600 0 115200
serial 2 0 115200 57600 0 115200
# led
led 0 5,7:S:ATB:4
led 1 6,7:S:AT:6
led 2 7,7:S:AT:6
led 3 8,7:NS:ATB:1
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 1
mode_color 0 2 1
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 2
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
# aux
aux 0 0 0 1125 2100
aux 1 1 0 1275 1650
aux 2 12 1 1850 2100
aux 3 0 0 900 900
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
# adjrange
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# servo
servo 0 1000 2000 1500 45 45 100 -1
servo 1 1000 2000 1500 45 45 100 -1
servo 2 1000 2000 1500 45 45 100 -1
servo 3 1000 2000 1500 45 45 100 -1
servo 4 1000 2000 1500 45 45 100 -1
servo 5 1000 2000 1500 45 45 100 -1
servo 6 1000 2000 1500 45 45 100 -1
servo 7 1000 2000 1500 45 45 100 -1
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set yaw_control_direction = 1
set 3d_deadband_throttle = 0
set default_rate_profile = 0
set gimbal_mode = NORMAL
set acc_cut_hz = 15
set accxy_deadband = 40
set accz_deadband = 40
set accz_lpf_cutoff =  5.000
set acc_unarmedcal = ON
set acc_trim_pitch = 0
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf =  0.600
set baro_cf_vel =  0.985
set baro_cf_alt =  0.965
set mag_declination = 0
set pid_controller = MWREWRITE
set p_pitch = 80
set i_pitch = 30
set d_pitch = 44
set p_roll = 80
set i_roll = 30
set d_roll = 44
set p_yaw = 185
set i_yaw = 45
set d_yaw = 0
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 15
set i_level = 10
set d_level = 100
set p_vel = 120
set i_vel = 45
set d_vel = 1
set yaw_p_limit = 500
set dterm_cut_hz = 0
set gtune_loP_rll = 10
set gtune_loP_ptch = 10
set gtune_loP_yw = 10
set gtune_hiP_rll = 100
set gtune_hiP_ptch = 100
set gtune_hiP_yw = 100
set gtune_pwr = 0
set gtune_settle_time = 450
set gtune_average_cycles = 16
# dump rates
# rateprofile
rateprofile 0
set rc_rate = 90
set rc_expo = 65
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_rate = 80
set pitch_rate = 80
set yaw_rate = 50
set tpa_rate = 0
set tpa_breakpoint = 1500
set serialrx_provider = SPEK1024
set sbus_inversion = ON
set spektrum_sat_bind = 0
set spektrum_sat_bind_autoreset = 1
set telemetry_switch = OFF
set telemetry_inversion = ON
set frsky_default_lattitude =  0.000
set frsky_default_longitude =  0.000
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set frsky_vfas_cell_voltage = OFF
set battery_capacity = 0
set vbat_scale = 110
set vbat_hysteresis = 1
set current_meter_scale = 400
set current_meter_offset = 0
set multiwii_current_meter_output = OFF
set current_meter_type = ADC
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_roll = 0
set align_board_pitch = 0
set align_board_yaw = 0
set max_angle_inclination = 700
set gyro_lpf = OFF
set gyro_sync_denom = 1
set gyro_lowpass_level = NORMAL
set gyro_lowpass = 90
set gyro_notch_hz = 0
set gyro_notch_cutoff = 130
set moron_threshold = 32
set imu_dcm_kp = 2500
set imu_dcm_ki = 0
set deadband = 0
set yaw_motor_direction = 1
set tri_unarmed_servo = ON
set servo_lowpass_freq = 400
set servo_lowpass_enable = OFF
set airmode_activate_throttle = 1350
set failsafe_delay = 10
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_kill_switch = OFF
set failsafe_throttle_low_delay = 100
set failsafe_procedure = DROP
set rx_min_usec = 885
set rx_max_usec = 2115
set acc_hardware = AUTO
set acc_lpf_hz =  10.000
set acc_trim_pitch = 16
set acc_trim_roll = 2
set baro_hardware = NONE
set mag_hardware = NONE
set pid_process_denom = 2
set blackbox_rate_num = 1
set blackbox_rate_denom = 1
set blackbox_device = SDCARD
set blackbox_on_motor_test = OFF
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
set ledstrip_visual_beeper = OFF
# profile
profile 0
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set pid_delta_method = MEASUREMENT
set dterm_lowpass_level = HIGH
set dterm_lowpass = 100
set dterm_notch_hz = 260
set dterm_notch_cutoff = 160
set vbat_pid_compensation = OFF
set pid_at_min_throttle = ON
set iterm_throttle_gain = 0
set pterm_srate_ratio = 85
set dterm_setpoint_weight = 150
set yaw_rate_accel_limit = 220
set rate_accel_limit = 0
set accum_threshold = 130
set yaw_accum_threshold = 32
set yaw_lowpass = 0
set pid_controller = BETAFLIGHT
set p_pitch = 57
set i_pitch = 48
set d_pitch = 60
set p_roll = 51
set i_roll = 45
set d_roll = 60
set p_yaw = 70
set i_yaw = 45
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 8
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
rateprofile 0
# rateprofile
rateprofile 0
set rc_rate = 101
set rc_rate_yaw = 203
set rc_expo = 30
set rc_yaw_expo = 41
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set pitch_srate = 57
set yaw_srate = 0
set tpa_rate = 10
set tpa_breakpoint = 1650
Weedo, je me suis permis de mettre ton dump entre balises "Code", ça prend moins de place ;)
Prends un genre QX90 qui es direct compatible taranis..
julienf62
Message par julienf62 »
a priori le combo ultime du moment pour le FPV en indoor
QX95
Tanaris
FS SE
Nid_de_coucou
Message par Nid_de_coucou »
Félicitations Supernova !
Si je peux me permettre, tu le destines à quel usage ? Plutôt grand indoor type salles de sport/extérieur sans vent ou petit indoor type intérieur de maison/appartement.
-> Taranis x9d plus
-> Fatshark Dominator SE
Dans la maison le QX c'est un peu chaud, sauf si vraiment il y a beaucoup d'espace. Sinon il faut protéger les hélices pour éviter de tomber au moindre petit obstacle. Il est parfait pour l'indoor en salle par contre :)
Une frame type Tiny Whoop serait parfaite pour la maison par contre !
Nid_de_coucou
Ok merci Sky. C'est bien ce qu'il me semblait.
Ok donc : un Tiny Whoop pour la maison, un QX pour le gymnase, un 130 pour l'accro et mon 210 pour la vitesse.
Ça va commencer à me couter cher cette histoire, je le sens... :mrgreen:
-> Taranis x9d plus
Au passage un 3" (~130) c'est parfait pour le gymnase aussi !
julienf62
supernova a écrit ::gaga: bah voila , commandé un qx95
avec un ti set de batt, la protection d'helices et les hélices cités sur le post
j'ai aussi craqué ^^
tu peux me donné le liens vers le post des hélices stp ?
tu a pris quelle batterie ?
david-n
Message par david-n »
coucou bon je vient de changer ma cam de mon 95 j'ai mit c'elle ci http://www.banggood.com/Super-Mini-Ligh ... ds=myorder et la qualité a l'air au dessus de l'origine je vous en dirait plus aux grand jours demain.
